View MLD V2 Cache Information
Use this procedure to display information about the MLDv2 corresponding to each interface, port, and multicast group paired on a router.
- Select IPv6 MLD.
- Select the V2 Cache tab.
V2 Cache Field Description
Use the data in the following table to use the V2 Cache tab.
Field |
Description |
GroupAddress |
Specifies the multicast group address that others want to join. A group address can be the same for many incoming ports. |
Ifindex |
Identifies a physical interface or a logical interface (VLAN), which has received group reports from various sources. |
InPort |
Version1HostTimer |
Specifies the time remaining until the local router assumes that there are no more MLDv1 members on the IP subnet attached to the interface. This is applicable only for MLDv1 hosts. Upon receiving an MLDv1 report, this value is reset to the group membership timer. |
SourceFilterMode |
Specifies the current group state applicable on MLDv2 compatible nodes. |
